It is currently Wed Jun 18, 2025 5:37 am
 Post subject: 74 CR125 shock seals
PostPosted: Mon Jan 25, 2021 11:27 am
Does anyone have a source for shock seals for 74 cr125 rear shocks(360 showa)? I have found rotary style seals but no proper hydraulic axial seals.
Thanks, Brad.
 Post subject: Re: 74 CR125 shock seals
PostPosted: Mon Jan 25, 2021 2:01 pm
I got mine from 123bearings
https://www.123bearing.com/joint-US-10X25X10-PU94
PostPosted: Wed Jan 27, 2021 9:45 am
Thanks M@tt. How are you installing cup seals into the seal head? Do you machine it first? The 360 Showas are a 12.5mm shaft. I can find cup seals the right size but was looking for standard metal cased seals. I would be happy to use hyd cup seals. Just not sure how to install them into existing seal head.
PostPosted: Wed Jan 27, 2021 12:01 pm
Hey
The 12.5mm are for the ‘75 shocks , also available at 123bearings
No need to machine , the seals were a perfect replacement for the originals and pressed in.
I think Holly in Japan lists the original Honda seals and some metal cased replacements . (Hollyequip.com) use a translation tool
PostPosted: Thu Jan 28, 2021 7:48 am
Unless I wasn't searching properly I could only find the 24mm outer dia. size for 12.5mm shaft on 123bearing.com. Holly advertised a conversion kit for finned res. shocks for over $100. The other 12.5mm seals are for a 1980 CR250 I think.(which was kinda nice cause I was looking for those too!!).
PostPosted: Thu Jan 28, 2021 4:00 pm
I used the US12x25x10-PU94 on my 75
