It is currently Sat Jul 05, 2025 3:03 am
 Post subject: Is My MT250 Clutch Shot?
PostPosted: Thu Nov 03, 2005 10:25 pm
Does anyone have wear limits for the MT250 clutch plates?
I tore apart my MT250 Clutch. Prev. Owner couldn't get it to work properly and rode without it. After draining oil/water from crankcase, I took the cluth plates out. Kind of crapped up and stuck together. So, I'll clean them, and install them and see if they'll work.
Any other tips/advice?
Thanks to all.
PostPosted: Fri Nov 04, 2005 10:40 am
Be real careful with the clutch basket. They are made cheap and will break if you give them the slightest excuse.
Friction plate wear limit is 2.4mm thick.
PostPosted: Sun Nov 20, 2005 10:47 pm
Well, I took the clutch out, cleaned it the discs and padsand re installed it. But, the Previous Owner had the pressure plate on in the wrong position, so, it turns out the clutch is excellent and working great.
