It is currently Sat Jul 05, 2025 5:32 am
PostPosted: Thu Feb 09, 2006 9:06 pm
Just trying to figure out if the 75 seat will fit the 73/74 cr 250 elsinores? thanks
PostPosted: Fri Feb 10, 2006 11:47 am
No, different front bracket and position of rear bracket. But it is a close miss if you get the seat cheap enough, need something right now, and don't mind making your own attachment points.
PostPosted: Thu Feb 16, 2006 10:23 pm
I made a 1976 seat fit a 1974 buy taking the front tab off the 74 seat base and attaching it to the 76 plastic seat base. Then I made two short adapters from 1 inch aluminum strips bolted to the 76 seat brackets and another hole drilled to line up with the 74 frame.
