It is currently Sat Jul 05, 2025 5:59 am
 Post subject: Fox Air Shox pump
PostPosted: Fri Feb 17, 2006 12:24 am
Good afternoon ladies and gents,
for those of you out there lucky enough to have a set of Fox air shox could you please point me in the right direction for finding a suitable pump to adjust the pressures. According to the manual a normal high pressure won't do so what better than to try our forum and see if someone out there can help.
Thanks in advance guys.
regards
1974 Yamaha YZ360B
1977 Suzuki RM370B
1980 Honda CR250RA
PostPosted: Fri Feb 17, 2006 5:38 pm
I suggest going to your local mountain bike store and picking up a shock pump. I have one from Risse Technology. It comes with a doodad that allows the pump to be removed from the shock without losing any pressure so the setup is 100% accurate.
PostPosted: Fri Feb 17, 2006 7:49 pm
thank you very much - shall check that out ASAP
1974 Yamaha YZ360B
1977 Suzuki RM370B
1980 Honda CR250RA
Users browsing this forum: Google [Bot] and 36 guests
