Bike is running for second time. Rebuilt top end, developed air leak, runaway engine. Split case, replaced seals, bearings. Still a bit rich, but hard to properly jet when weather is 45 degrees lower than I expect to ride it in.
So, I now am starting to look at replacing worn chain/sprockets. I notice these rear sprockets are offset and most I see new are not. There is a steel on on DaBay, but I thought I might save some scratch buying a set of both gears and chain. Where are you guys buying these?? I'm assuming any 520 non-o-ring chain will work, but what about that offset rear sprocket??
Thanks, Mitch
