It is currently Sun Jul 06, 2025 3:09 am
PostPosted: Wed Apr 05, 2006 9:35 am
I searched and read what I could find...Seriously considering ordering one for my bike. Does this ignition require machining of side cover or flywheel?
Anything else I need to know? Thanks
1974 CR250 Elsinore..Roseville, Ca
PostPosted: Wed Apr 05, 2006 11:46 am
Site Admin
No machining. Pretty easy install. I installed one on my 73 CR250M and it works great. No more points problems! I don't even think about the ignition anymore, much less worry about it. If you have the $$$ (they ain't cheap) go for it.
PostPosted: Wed Apr 05, 2006 3:49 pm
I've run one for about four years now and it works great. Highly recommended if you have the bucks.
Loren Davis
51y
PostPosted: Thu Apr 06, 2006 7:14 am
Thanks :D I'll start saving up...
PostPosted: Sun May 21, 2006 3:33 pm
Well after destroying two pairs of boots and one ankle from kickback, :lol: the PVL ignition is finally installed!! Set the timing at .070” btdc..Seems to have a lot more power and runs very smooth. Would highly recommend the switch from points and advanced timing. Also saves on kick start pawls and ankles. 8)
PostPosted: Tue May 23, 2006 6:48 am
How much are these units???
PostPosted: Wed May 24, 2006 8:32 am
$375 from http://www.pro-flo.com
PostPosted: Tue Jun 13, 2006 5:23 pm
Does the Instructions for the PVL Ignition tell you what to set the timing at? I would think so. I know it's mentioned here at .070 at btdc.
Forrest Rohrs
1982 CR250R
1980 CR125R
1974 CR250M
PostPosted: Tue Jun 13, 2006 6:58 pm
Site Admin
 Post subject: 74 CR250 PVL
PostPosted: Tue Jun 13, 2006 8:39 pm
There we go!
Thank you Sir!
Forrest Rohrs
