It is currently Sat Aug 16, 2025 11:19 pm
PostPosted: Sun Jan 25, 2004 8:12 pm
Will a kick start assembly made for a 73-74 250 fit in an 76 175?
O ya the 250 is a CR and the 175 is a MR not sure if this matters or not.
PostPosted: Sun Jan 25, 2004 8:13 pm
No it mounts from inside the case the 250 mounts from the outside and is different. A CR125M or any MT125 mechanism is the same. You need to split the cases to install the shaft or return spring.
