It is currently Sat Aug 16, 2025 11:56 pm
PostPosted: Thu Mar 11, 2004 7:27 am
I get no response from Vintage Elsinores. I have tried other places with similar results. Where can I get a sleeve pressed in. Also, What are the advantages or disadvantages of sleeving as opposed to getting the cylinder replated with nickesil? Where do you get these jugs re-plated? Thanks!!!
PostPosted: Thu Mar 11, 2004 9:55 am
Hi Jack,
I'm certainly no expert, but I've been trying get answers to the same questions. This is all I've been able to find out so far:
Sleeved: Cheaper after initial install because you can have 4 or 5 re-bores. Better heat dispersion (claimed). You must use a chrome ring.
Re-plated: Must re-plate after wear or damage. Less drag and therefore a little better revving and power. Better heat dispersion (claimed for H2O cooled). You must use an iron ring.
L.A. Sleeve http://www.lasleeve.com or Rick Peterson Motorsports http://www.rpmsbigbore.com/repair.htm would probably be good places to talk to. Here is a re-plater in Pennsylvania http://www.lukesracing.com if you are on the East coast. Sometimes there is a good local or regional business that can do it. Ask other racers in your area or talk to someone at a local MX event. Good luck!
J
#829 The "Factory Novice"
1988 Honda CR250RJ
1983 Honda CR480
1981 Can-Am 250 MX6-B
1979 Honda CR250RZ
1979 Kawasaki KX250 A5
1978 Husky 250CR
1978 Honda CR250R
1977 Yamaha YZ400D
1977 Suzuki RM125B
PostPosted: Thu Mar 11, 2004 1:37 pm
I used Racers' Toy Store in Escondido to fit an LA Sleeve kit to my CR250R 1979 cylinder. The chrome plating is technically superior, but the sleeve continues to work just fine 2 years on. I believe US Chrome and Eric Gorr will re-plate your cylinder if you do want to go that route.
PostPosted: Thu Mar 11, 2004 5:00 pm
i took mine to a local shop a while ago, but i think they said they send it to wiseco pistons to get it done. so you might want to check wiseco's website.
1980 cr250r
 Post subject: plating
PostPosted: Sat Mar 13, 2004 6:12 pm
Hi we do most of our replating with US Chrome. They do excellent work and turn around time isnt bad unless it is snowmobile season.We also offer overbore kits with porting and replating for VERY reasonable money.We also stock all 78-80 Cr250R pistons , bearings,gaskets,etc.We can also modify your head and or cylinder for whatever fuel you want to run.We are seeing over 3 horsepower gain on the dyno with just a fuel change.Let me know if we can help you.You can email me at mailto:johnkerr23@msn.com or call the shop at 863-956-1255.
Users browsing this forum: Google [Bot] and 9 guests
