For 73/74 CR shocks, here's what I do: dissassemble them, dump out old oil, clean all internal parts with solvent, clean bodies in the sink with hot water and a nylon bristle brush, wet sand the bodies with fine waterproof sandpaper, sand out all corrosion and dents, mask off rubber eyes, paint the bodies with aluminum coloured paint from a spray can (or the best matching colour you can find), clear coat with urethane from a spray can, straighten the rods if they are bent, re-hard-chrome the rods if they are corroded, replace the seal (there are 2 different sizes depending on the year), wet sand the alloy spring keepers and top eyes then polish with metal polish and clearcoat, sandblast the springs and paint semigloss black, clean up the plastic spring shield with sandpaper and paint semigloss black, fill with 5 weight oil (too much and the travel binds, too little and the damping is not full stroke), re-assemble and check operation by hand, install springs and keeper, add Showa 360 sticker, armourall the rubber in the eyes.
