Hi, I've been lurking here quietly for a while, usually finding the info I need from old questions asked, but I'm not sure about this one. I've got a 75 CR125 with an MR175 engine installed, and I have to split the center cases to replace the kick starter return spring, and I was thinking I should try to improve it a bit while I had it apart.
I've read here that you can replace the MR point ignition with a CR125 system, but the 125 has a bolt and the 175 has a nut on the crank end. What kind of puller would remove this setup on the MR? or is there a 125 rotor that is designed for the MR crank end (76, 77 maybe)?
I've also read that you can replace the transmission with the CR, does anyone know if you need to use the clutch and crank gears or the sprockets from the 125 as well to make this work right?
Thx Hans
