They will work just fine. I am 185lbs plus gear and run 140lbs in the lower high pressure chamber, and 80lbs in the upper low pressure chamber. I now someone who re-furbishes these and does an awesome job. Beating Maico 490s (and Honda CR480Rs too) is a more holistic challenge, but you are heading in the right direction.
...I am pretty sure that the extra thickness of the Fox arm is going to pinch the chain against the forward roller. I run a set of thick nylon washers mounted on a bolt threaded into the stock mount. Contact
http://www.jastco.com for a more comprehensive solution that includes a new roller mount and a longer torque arm.
