It is currently Wed Jun 18, 2025 12:47 am
PostPosted: Tue Sep 25, 2007 1:19 pm
I have just bought a 1979 250 Maico Magnum
Proper Enduro model, with Steering lock on headstock and correct tank using the plug in black connector Bosch ignition - she looks great and pulls like a train....
My problem is that I am entered into an Enduro in France (I am in England) on the 14th October and the bike must have working lights.....It has a headlight and Tail light but no wiring connecting them. There are several spare wires taped up under the tank, I am quite happy to carry out the wiring I just need to know the colours to use...and how to check them, I have a multimeter available.
It has a horn attached, and I have bought a high/low /horn switch , as well as a rear brake light switch...
As it says in the heading .........HELP !!!!!!!!!!!!!!!!
Graham
PostPosted: Thu Jan 10, 2008 7:36 pm
Hello, I just found this site. Did you find the info that you needed? There is a Yahoo group on Maico motorcycles that has a lot of info. It has wiring diagrams on the enduro. Hope this helps. I have a '79 440 enduro that I need some various parts for if you know of sources. Maybe we can help each other out. Stacy
