It is currently Fri Aug 15, 2025 7:39 am
 Post subject: Fork Oil Question
PostPosted: Fri Feb 29, 2008 9:33 pm
I was looking at the manuals section under 74 CR250 and found that 145cc of fork oil is required to refill the forks.
The manual I use for my 83 CR480 tells me that I can measure from the top/inside of the forks to the top level of the oil.
Does anyone use this method to top off the fork oil or make adjustments to the level?
If so, what measurement are you using?
Thanks,
 Post subject: Re: Fork Oil Question
PostPosted: Sat Mar 01, 2008 12:29 am
Yes, but it just makes sense to pour the measured amount in. I think it works out to around 5 - 6 inches (forks collapsed). Doesn't your more modern manual give some cc measurement too?
Users browsing this forum: No registered users and 10 guests
