It is currently Thu Aug 14, 2025 4:32 pm
PostPosted: Fri May 16, 2008 7:59 am
From the Swap Meet...
Can anyone tell me the difference between the lower end of a 81 cr450 and the 82 cr480 are the bearings and seals the same? My cr450 needs crank bearings or the bearings are spinning in the case and cant find them any where. Any help would be appreciated...
If you visit http://www.cmsnl.com you can view a parts fiche/catalog. It will show where parts have been superseded and if they have the later parts available. In this case...
91009-HC0-0003 Bearing 26x68x18 (2) - shared with CR480R and CR500R models
91201-KA4-004 Seal 38x58x11 - shared with most CR250R and CR500R models from 1980s and 1990s
91203-444-003 Seal - shared with 1982 and 1983 CR480R
Parts are all available, but priced in Euros and therefore expensive. However you can use the dimensions and part # to source elsewhere.
BTW, this took me approximately 10 minutes in Internet time.
PostPosted: Fri May 16, 2008 10:49 am
crank bearings are 63/28 C3
you can get them and the seals in a bearingshop
or look at ebay, someone sells bearing/sealkits
