It is currently Fri Jun 20, 2025 7:47 pm
PostPosted: Fri Aug 08, 2008 6:57 pm
I have a '78 CR250 that hung a ring and damaged the cylinder. Does anyone have any experience with a sleeved cylinder compared to a rechromed cylinder? I will only race this bike about 4 times a year and practice with it a little more. Also, if I rechrome it, what would be an average price? Thank you.
PostPosted: Mon Aug 11, 2008 12:54 pm
Personally, I go for Nikasil replating (I don't think you'll find a place to rechrome) over sleeving. The upside to sleeving is that you can do overbores down the road when you need to have a fresh top end. The downsides are that the sleeves rarely perfectly match for the ports (though you could probably smooth that out with a proper epoxy) and that the cylinder is no longer as thermally efficient.
I think the up front cost is roughly the same if you factor the cost of the sleeve in. Replating is about $200, with a bit more if the cylinder needs a deep gouge repaired.
The replating services I see mentioned the most with good reports are:
http://www.usnicom.com/ (I believe Eric Gorr uses them)
http://www.powersealusa.com/
http://www.mt-llc.com/
PostPosted: Wed Aug 13, 2008 12:29 pm
Hello,
The damaged chrome can be stripped. If there's damage to the aluminum bore, it can be rebored to the next cleanup size and then replated , Nikasil, whatever. This way you don't need to worry about port alignment, or a poorly fitting sleeve. If you bore and replate, you have just given yourself a new, your standard, bore size.
1978 CR250R
1980 CR250R
1980 ME360
1986 CR250R
