It is currently Fri Aug 15, 2025 9:18 am
PostPosted: Fri Jan 02, 2009 10:09 am
I picked up a ATC250 cylinder head and barrel, and I noticed that it does not have the 2 head locating dowels that my 78 and 80 heads have. I want to put it on a 1980 bottom end, should I machine the dowel holes or not worry about it? I guess honda felt they were not needed in the ATC motor, but added the rubber dampers in the fins.
I have too many....
PostPosted: Mon Jan 05, 2009 8:17 pm
Update: I took a closer looking at the ports and they do not match the CR250 ports on my 78 and 80 cylinders, much smaller in size. I guess the ATC was sold with a milder tune, so I am scrapping the idea of putting this head on my 80 cases.
Is there anyone out there who has ridden one (ATC250R) to compare what type of hit this one had compared to a CR?
I have too many....
PostPosted: Mon Jan 05, 2009 10:17 pm
i have had several atc's. there are large sand dunes here and if you don't have a dune machine you ain't sh+t. the air cooled atc 250s were mild on the power band just good smooth power all the way trying to get picture of my dune ripper to come up
PostPosted: Tue Jan 06, 2009 5:05 pm
the atc250 has about 10hp less than the cr250. :(
