It is currently Fri Jun 20, 2025 1:15 pm
PostPosted: Tue Jan 06, 2009 9:55 am
I am shopping for a new evo bike to run in the WORCS series and i found a 83 CR250. I can run a 1984 but the 83 seems to be a decent deal. Let me know any plus's or minus's you guys may know of. thanks!!
PostPosted: Tue Jan 06, 2009 7:17 pm
waterpump corrosion is the BAD of all 83 CR250's-hard to find good replacements-otherwise an excellent bike.i had one and i liked it.............
PostPosted: Tue Jan 06, 2009 8:59 pm
On this board, and at http://www.cr500riders.com this problem has been discussed. It is possible to repair the corrosion and then use a spray coating from Devcon to protect the case from the coolant in the future. There is also a special coolant for magnesium block engines that prevents this type of damage.
PostPosted: Thu Mar 12, 2009 3:33 pm
The bad:
Waterpump Corrosion Has been discussed already. I will add that Evans Coolant should be used. Most GOOD dealerships have this in stock.
Clogged Radiators Because of the corrosion in the WP area.
Suspension Even if the shock has dampening make sure the clickers WILL turn. Most won't. Check linkage. Some parts are not available OEM. No aftermarket either. The are bushings not bearings. Insert zerk fittings. Forks If you can get away with it slide in a front end from an 88 CR250. They are the best. At a minimum use a 86. (first yr. for cartridge forks)
Chain Defense Sliders
Check these because they are not avail. OEM. But can be had overseas. (Australia)
The Good:
Everything Else!!
Hope this helps!
83 CR250
83 CR480
87 YZ250
88 CR250
74 TY250
07 YZ250
83 RM250 on the resto table
91 YZ250 with an Ohlins 360 kit in resto que
83 CR125 in resto que
PostPosted: Fri Mar 13, 2009 11:24 pm
Sliders available from Red Devil Racing. Shock rebuild and anodizing from Rich Truinski at Tru Technologies. Springs from Eibach.
PostPosted: Sat Mar 14, 2009 3:24 pm
But are there any waterpump/clutch covers available. :?
Users browsing this forum: Google [Bot] and 44 guests
