Wow, two tablespoons - quite a bit! Even half a teaspoon would have me a little nervous (I'm a big fan of fuel filters). Speaking of which... I don't know if you still have the stock petcock, but if so I would definitely unscrew the sediment bowl and pull out the brass screen with needle-nose pliers - might be all sorts of exciting things waiting to be discovered. :>) Come to think of it, my buddy's '74 MT250 had grit in the carb too, and he was always having trouble with the carb leaking and overflowing... hmmm....
My MR175 uses the same petcock, and I had to do a bunch of work to it to keep all the tank rust from clogging up the main/reserve inlet 'snorkels'. I finally got it working OK, but I ended up biting the bullet anyway and getting a Clarke tank.
You might have gotten lucky and all the grit stayed within the carb, but if it were my bike I would moisten a paper towel slightly with gas and rotate it through the crankcase using the crankwheels, and see what (if anything) it picks up. And blow out the carb well, of course, especially all the passages related to the pilot circuit (there's a bunch of 'em) and the passage from the air jet to the needle jet.
_________________ '74 CR125M (175cc), '75 MR175, '82 RM250Z, '08 YZ250F, '14 Zero FX electric, '14 Zero MX electric, '18 Alta MXR electric
