It is currently Fri Aug 15, 2025 7:06 pm
PostPosted: Mon Mar 23, 2009 10:10 am
hello,
i need some help please.i have a very early cr250m engine that has the serial number stamped in a straight line across the block.it has the billet crank in it.my question is will the later style forged/cast crankshaft work fine in this original block or will it cause problems? as you know it is shaped a bit different.thank you for your time!
Mark Ayer
mailto:jarrett8@earthlink.net
PostPosted: Mon Mar 23, 2009 2:31 pm
Mark,
The billet and cast cranks are interchangeable.
If you have a billet crank in good shape, use
it. Billet/forged cranks are stouter than the
cast units.
Users browsing this forum: Bing [Bot] and 13 guests
