It is currently Fri Aug 15, 2025 9:24 am
PostPosted: Sat Mar 28, 2009 6:58 pm
I am in need of bearings, seals, gaskets, pistons, and rings for both a 1974 CR250m and 1977 CR125.
Does anyone know of a relaible place to get these parts?
I live in Southern California.
Thanks,
Jim
JimN
74 CR250, 75 CR250, 77 CR 125, two 83 CR 480s
74 TM125, 79 RM100
PostPosted: Sun Mar 29, 2009 7:47 am
Bike Bandit has always worked for me. Good luck !!!
77 MR175, 89 HD Sportster
74 CR125, 00 Kawasaki ZG1000
79 XR185, 56 Cushman Eagle
03 XR650L, 79 Vespa P200E
72 Vespa Super150,
74 HD Z90
PostPosted: Sun Mar 29, 2009 11:15 am
you can get most engine parts on ebay and http://www.mossbargerracing.com/ does a bolt on reed valve with no mods I've got one on mine and it makes it quicker out of the corners , I didn't think it improved anything else though , but I wouldn't go back to piston port because of bogging down and running on
PostPosted: Sun Mar 29, 2009 12:36 pm
Living in SoCal, you are in a parts rich environment. Like Showtime said, Bike Bandit
(San Diego) can help with a lot. They have the seals, gaskets and most of the
bearings. For crank bearings, I recommend Wiseco. They offer a kit that contains
two crank bearings that are the same as the OE bearings for much less money.
The problem is the clutch actuator bearing, it is NLA. If you have the original, you
can take it to a bearing supply and see if they can match it.
For the piston and rings, I would go with Wiseco again. Their kit comes with the
piston, rings, wristpin and circlips and is available in most sizes. You can pick this
up at Chaparral in San Bernardino.
I strongly recommend you stick with either Japanese or American made bearings and
Honda seals. They will provide you with an airtight durable engine.
I don't know how much these sources will help you with your tiddler.
Users browsing this forum: Google [Bot] and 19 guests
