It is currently Sat Aug 16, 2025 5:27 am
PostPosted: Tue Jan 06, 2009 2:10 pm
how do i remover lower bolt that has the compression adjuster in it? It just spins in place when loosening?
PostPosted: Tue Jan 06, 2009 7:31 pm
Impact driver or air wrench usually works.
77 MR175, 89 HD Sportster
74 CR125, 00 Kawasaki ZG1000
79 XR185, 56 Cushman Eagle
03 XR650L, 79 Vespa P200E
72 Vespa Super150,
74 HD Z90
PostPosted: Tue Jan 06, 2009 7:53 pm
Put an impact driver on it...150 ft/lbs or so should be plenty!
PostPosted: Tue Jan 06, 2009 8:52 pm
Turn the forktube upside down and place it on a piece of wood on the floor. Press down (compress) as tight as you can on the tube from turning while someone else uses the impact to remove the bolt.
Terry Moody #48f
3x 74 Honda CR250M Elsinore
74 Honda XR75
73 Honda QA50
78 Yamaha YZ125E
78 Yamaha YZ250E
78 Yamaha YZ400E
79 Kawasaki KX250
79 Honda CR250R
79 Suzuki RM400
80 Honda CR125
2x 83 Honda CR480R
98 Kawasaki KX250
PostPosted: Mon Jan 12, 2009 8:54 am
pushing and impact did the trick!! thanks guys
PostPosted: Wed Sep 02, 2009 2:42 am
Another great trick is to take a wooden broom handle (minus the sweeper part) and put it into the fork. Turn the fork upside down resting on the wooden handle, then push down and "HIT" it with the impact driver. On a simple damper rod fork the wooden rod will be pushing on the damper rod and hold it in place...
BTW, I know this is an old thread, but in the future if anyone is ever searching they can see several methods to try and help them get their forks apart - actually just used this method on a stubborn V-Max a few months ago that just would not come apart!
Peace crew.
Mikeee P
The Race Isn't Over Until YOU Cross The Finish Line!
