Gregg,
OK, that makes sense - with a high float level and a way-too-lean main jet, the bike might still run a little rich below full throttle (masking the lean main jet) and then really lean wide open. I never could understand why every jetting-related thing I ever read always recommended setting the float level before anything else, but these days I do. I would also check to make sure that the needle and seat are sealing well, as these are famous for wearing out (replacements can be hard to find, but they're out there).
The bubbles in the fuel line may have been caused by the O-ring disintegrating and the float bowl/carb/motor filling with fuel. But yes - case cracks, case gaskets, main bearing seals, and leaks of all stripes can cause leanness. Unbeknownst to me, my CR's left main bearing cage fell apart, the sloppy crank destroyed the seal, and the bike ran leaner and leaner - I compensated by jetting richer, but I never could get back the power lost from low primary (crankcase) compression. Luckily I discovered it before the cage bits did any damage.
Not only does Wiseco make replacement pistons up to 2.0mm oversize (339M05600, etc.), but apparently Honda still makes the standard and .25mm oversize pistons, .25/.5/1.0mm oversize rings, piston pin, bearing, etc. I don't know about standard ring sets - you might have to check eBay. If you go the Wiseco route, you might want to call them to double-check first (ask them if they provide full piston sets w/pin/bearing/etc., or just single pistons as the Web site seems to indicate).
Believe it or not, .25mm OS pistons and rings fit perfectly and ran great in my CR, which I bought new and never bored out. I guess it was just bored too big from the factory.
_________________ '74 CR125M (175cc), '75 MR175, '82 RM250Z, '08 YZ250F, '14 Zero FX electric, '14 Zero MX electric, '18 Alta MXR electric
