tell me how to get this thing off
The lower race is pressed on. If you have access to a hydraulic press, place the
steering stem on a set of press plates with the stem pointing up and a hole for the
stem to pass through below. Press the stem down and out of the lower triple clamp
and the race will come off. When you are ready to install the new lower race, press
the stem in the lower triple clamp from the bottom until seated. Then place the new
race on the stem, turn the assembly over with the stem poking through the hole in the
press plates. The hole has to be big enough to allow the stem to pass through but small
enough to support the bearing race. Press the assembly down until the new race is seated.
If you don't have a hydraulic press, take it to a machine shop.
