It is currently Sat Jul 05, 2025 5:05 am
PostPosted: Wed Feb 08, 2006 8:02 pm
Does anyone know where I can acquire some aftermarket tapered steering stem bearings to replace the old loose ball bearings and races on my 1974 CR 125? :?:
PostPosted: Wed Feb 08, 2006 8:47 pm
Don't know if this will help but denniskirk.com has them but does not list them for 74 model. It starts at 76, however by looking at the part# all small hondas with the exception of the cr80's and the 79 and up cr125"s use the same part # which is 50-5737. Maybe someone else knows or you could order them and try them
 Post subject: tapered bearings
PostPosted: Thu Feb 09, 2006 2:59 am
wouldn't mind a set for the 73 250 either by the way?
1974 Yamaha YZ360B
1977 Suzuki RM370B
1980 Honda CR250RA
PostPosted: Thu Feb 09, 2006 5:29 pm
Same results as above listing starts at 76 but at 78 they used diffrent ones just about every year. I dont have a chance to check today, but I have the parts list for cr250m and I'll check if Honda used the same bearings on the 76 MR as they do have a listing for the MR
PostPosted: Thu Feb 09, 2006 9:40 pm
I checked out the 76 MR parts list and 73/74 CR list and the Honda part #'s are the same for the original bearings and races. You could try the tapered ones for the MR and let us all know if they fit
PostPosted: Fri Feb 10, 2006 12:06 am
Measure the diameter of steering tube and shaft.
Your nearest bearing supply store should be able to find a set in their metric catalogue .
'84 Honda CR500
'84 CR125
'85 KX125
'83 IT490
'82 Maico 490
'80 YZ465
'75 Husky CR360 GP Mikkola
'75 CR250
'72 DT2MX
'91 XR200
PostPosted: Sat Feb 11, 2006 1:04 pm
I just ordered a set of the '76 tapered bearings from Dennis Kirk. I'll let you all know if they fit the '74.
PostPosted: Fri Feb 24, 2006 7:20 pm
I recieved the Moose tapered stearing stem bearings from Dennis Kirk the other day (listed for '76-'78 CR125). The dimensions are identical to the stock 1974 ones so I installed them on my '74 CR125 and they work just fine. I spoke to the tech guy at Dennis Kirk who should be making the adjustment to their "Models Fit" description on their website. Spread the word! :D
 Post subject: This site lists them
PostPosted: Wed Mar 01, 2006 12:21 pm
http://www.re-mx.com/cr/cr125_cr250.php
I don't know how the price compares to Dennis Kirk.
Users browsing this forum: Google [Bot] and 38 guests
