It is currently Fri Jul 18, 2025 3:43 am
 Post subject: 1979 CR 250 Timing
PostPosted: Sat Apr 19, 2008 5:14 pm
How do you set the timing with the adjustable mag cover?
Thanks,
Dan
 Post subject: Re: 1979 CR 250 Timing
PostPosted: Sat Apr 19, 2008 9:25 pm
If you want stock timing, use the dowel to pin the cover in the stock position.
PostPosted: Sat Apr 19, 2008 9:29 pm
Thanks. Moving the cover clockwise advances or retards? Are you going to Perris tomorrow?
Thanks, Dan
PostPosted: Sun Apr 20, 2008 9:19 pm
Looking at the bike from the right-hand ignition side, the crank is rotating clockwise so I assume turning the rotor cover counter-clockwise advances the ignition and vice versa.
...and no racing is out until either of my motors are re-built. I am racing my '07 CR500R instead.
