It is currently Fri Jun 20, 2025 10:25 pm
 Post subject: MR 175 Air Filter
PostPosted: Wed Aug 06, 2008 8:37 pm
Cant get a stock filter. Does anyone have a suggestion for a replacment or modification that would work. 1977 MR 175. Thanks
 Post subject: Re: MR 175 Air Filter
PostPosted: Wed Aug 06, 2008 10:28 pm
Good luck. I have looked for this filter for years. I gave up and made my own.
If you still have the old filter cage, you can try what I have done. It works great, but takes a little patience.
You can buy universal sheets of filter foam at most well equipped bike shops. Cut pieces and rap around the steel cage until you have a good fit. Then use a hot-glue gun and glue the joints.
If that is too much trouble, K&N air-filters make universal cylinder-shaped filters that with the right boot will clamp right on to the carb. Not so good for the real dirt, as water can get sucked in.
good luck
PostPosted: Thu Aug 07, 2008 11:34 am
Thanks for the glue gun idea. I have the filter sheet. The glue gun will make it easier to get a good fit.
PostPosted: Tue Aug 26, 2008 8:50 pm
I found a UNI filter for the mr175 - part number NU 4026. I bought it from dabbernz on ebay. Search feedback forum to find a contact link. He's in New Zealand but shipped very fast and was great to deal with. The US Uni site doesn't list it but the package references http://www.unifilter.com.au - you may be able to get it direct.
PostPosted: Sat Aug 30, 2008 12:16 pm
Thanks. I will look him up.
Users browsing this forum: Google [Bot] and 19 guests
